C51 Libraries and reentrancy
In http://www.keil.com/support/docs/1873.htm Section 2; It is said that some of the library functions are inherently reentrant because they only use registers for local variables... If only SOME are reentrant in this manner, please list those functions that require reentrant stack to be defined in STARTUP.A51.
Thanks,
Glenn
  • If only SOME are reentrant in this manner, please list those functions that require reentrant stack to be defined in STARTUP.A51.
    None of the library routines use the reentrant stack.
    The reentrant library routines are so indicated in the Library Reference section of the Compiler manual.
    Jon
    Jon
