Hello, I am using the Keil PK51 (Version 5.5) on a Windows XP computer now, unfortunately the european version of the Keil tools, which requires a dongle. For this reason, there are Windows NT drivers that have to be used so that the system can "find" the dongle. That works good, most of the times, but every 10th compiler run hangs up. The WinRun DOS window doesn't come to an end anymore, and that's it. Every attempt from that point on to compile anything results in the same behavior. Windows has to be rebooted in order to make it work again. Now, that gets a little bit annoying, since it seems to happen more often every day. Is there a solution for this? Thanks for any help! Holger
