assembler macro included in C macro
l.s.,
For delay purposes I need NOP's in an assembler macro, the code below doesn't do the trick. Thread 2267.htm doesn't help me either. A C macroloop, with e.g. DELAY(a); a = 10, slows the execution down too much. Can Anyone help me?
thanks, ***
#define DELAY(a) \
volatile unsigned b; \
for(b = 0; b < a; b++) \
#define DELAYNOP \
#pragma asm \
NOP \
NOP \
NOP \
NOP \
NOP \
NOP \
NOP \
#pragma endasm \
    The simplest form of a delay is:
    void Delay (unsigned char Cycles)
       // The following generates:
       // C0001: DJNZ R7,C0001   ; 1 to 256 times
       while (--Cycles);
    If you want to avoid the call use:
    #define Delay(Cycles) { while(--Cycles); }
    If you need a longer delay modify the function to be:
    #include <intrins.h>
       do {
          _nop_();  _nop_(); ...
       } while (--Cycles);
       while (--Cycles);
       do {
       } while (--Cycles);
