inline assembly help linker error
#include <reg5000.h>
#include <stdio.h>
void main(void);
void writebyte (unsigned char ch);
void main()
	unsigned char ch;
	ch=0x0A;
	writebyte(ch);
	ACC=ch;
#pragma ASM
	PUSH	MCON
	ORL	MCON,	#4
	MOVX	@R0,	A
	DEC	R0
	POP	MCON
#pragma ENDASM
When compiling I get the following linker warning.
*** WARNING L1: UNRESOLVED EXTERNAL SYMBOL
    SYMBOL:  ?C_STARTUP
    MODULE:  rtc-func.obj (RTC_FUNC)
I followed the directions in the manual about in-line assembly and the ASM/ENDASM directives which stated
Right click on the file in the Project Window - Files Tab
Choose Options for... to open Options - Properties page
Enable Generate Assembler SRC file
Enable Assemble SRC file.
I also tried adding the STARTINIT.A51 file and get the same linker warnings except that the warnings are in the STARTINIT.A51 file instead.
Any help out there? I know it has to be something simple...
  • Doh!!
    Just to follow up...
    I found the answer here:
    http://www.keil.com/support/docs/1980.htm
    and for those too lazy to look above, here it is...
    CAUSE
    When you compile all your C modules with the SRC directive and the assembler, the linker does not detect the required C run-time libraries (because the files were assembled). In this case, you must add the libraries to your project manually.
    RESOLUTION
    For a project in the SMALL memory model that uses no floating point arithmetic, C51S.LIB is required.
    For a project in the LARGE memory model that uses floating-point, C51FPL.LIB and C51L.LIB are required.
    If a project uses floating arithmetic, it is important that C51FPx.LIB is included before the standard library file C51x.LIB. Otherwise printf and scanf will not work with floating-point numbers.
  • Doh!!
    CAUSE
    RESOLUTION
