testapplication for bit-banged i2c
Hi.
I have built a bit-banged i2c on the 89c668 and want to test this in uVision2. The hardware i2c port is also in use and can be tested with the standard peripheriral. I would like to have something comparable like this for the bit-banged one. I use the port 0_3 for SCL, and the port 0_2 for SDA. Do you, or anyone, have some example code or running testapps?
thanks, ***.
