combine assembler files with C code
it seems that i made a mistake, while posting the message. I can't read the answers. So lets have another try!
How can i combine assembler files and C code. How do i hand over the paramters in a function call? How must the function declaration look like in the headerfile? For example: application written in C that calls for example an I2C routine, that reads from an I2C ROM written in assembler.
thanks for answer,
Markus Kammersberger
  • In the manual, there is a section titled "Interfacing C to Assembler" (or similar) - you need to read it!
    The manual also describes the parameter-passing and return value mechanisms used by C51 - your assembler must follow the same rules!
    The simplest way is to create a "skeleton" in C51, examine the generated assembler, then put in your required functionality
