func and func()
Hi All,
let a function prototype is :
bit func();
Now if it is used as follows (inadvertently) then what would it do ?? Why not the complier throws an error ??
if (func) {
else {
-Rocknmoon()
  • "if (func)"
    Funnily enough, I made that very same mistake only the other day!
    As Mark says, the expression 'func' has the value of the address of func; the if simply tests if the value is zero or not - almost undoubtedly it won't be, so it will always equate to "true"
    "The compiler could warn..."
    As I have noted several timed before, "small" cross-compilers like C51 are generally weaker in their diagnostic messages than their "big" native cousins like MSVC, Borland, etc
    Therefore it is often worthwhile running your code through a "big" compiler for the benefit of the more extensive diagnostics.
    Or use lint
  • "if (func)"
    Or use lint
