Hi all, we need to (re)write a bootloader that uses XRAM to execute the bootloader code to modify the FLASH code memory. How can i avoid overwritting variables from within the application firmware to write to the XRAM bootloader code? How do one manage RAM memory in such a case? Best Regards.
Never used the C51 but I can tell you how I do it for C166. I enter 0xC000-0xD7FF in the "Reserve" box on the "L166 Misc" tab under "Target options". This insure that the linker will not locate variables or anything else in this memory block. I then use xmemcpy as described in APNT138 to copy my FLASH utilites to that memory block starting at 0xC000. Hope this helps, Walt
