Hi All,, The Data is serially coming into my controller , is processed there and then sent out serially. The data is packed between header (8 zero bytes) and tailer (8 0xff bytes). Should i detect for the valid header and then start adding the incoming data into the fifo() and then just process the data. Or should i push all the incoming bytes into the fifo() and detect the valid header from there and then process the data ?? Any goood reasons for any preference ?? Thankzz && Bye -Rocknmoon
