Hi Everyone: I am from China.I have a question that is need your help.That is I wanted to use some 8051 pins to emulate PWM output signals,please tell me source program about KEIL C for 8051.Thank you! yours truly JianJian
Hi Jian Jian! Well, many C51 derivates have PWM on chip. Other than that, yopu can do that with a timer interrupt. Trigger the interrupt of the timer like every mili second and then count the HIGH and LOW times of your signal with a counter... teh resolution will not be really great, but for some purposes it works... you can sure set the resolution to less than a milli second of course, but when it is too short, you will spend all processor time for the PWM signals. Take care, Sven
