Warning: Not directly related with Keil... After the messages on the pointer and function pointer usage, I read the application note 129 and confused on the syntax of calling functions using funct. ptrs I was using the syntax below:
void f() { } void (* fptr)(void) = f; ... void main() { fptr(); }
(*fptr)();
#pragma CODE DEBUG SYMBOLS LISTINCLUDE LARGE ROM(LARGE) #include <reg52.h> void func_caller( int (code *fptr)(unsigned int) reentrant) { unsigned char i; for (i=0; i<10; i++) { fptr(i); } for (i=0; i<10; i++) { (*fptr)(i); } } int func(unsigned int count) reentrant { long j; long k; k=0; for (j=0; j<count; j++) k+=j; return(k); } void main() { func_caller(func); while(1); }
6 void func_caller( 7 int (code *fptr)(unsigned int) reentrant) 8 { 9 1 unsigned char i; 10 1 for (i=0; i<10; i++) { 11 2 fptr(i); 12 2 } 13 1 for (i=0; i<10; i++) { 14 2 (*fptr)(i); 15 2 } 16 1 } ; SOURCE LINE # 11 0015 7E00 MOV R6,#00H 0017 900000 R MOV DPTR,#fptr 001A E0 MOVX A,@DPTR 001B FC MOV R4,A 001C A3 INC DPTR 001D E0 MOVX A,@DPTR 001E FD MOV R5,A 001F 8982 MOV DPL,R1 0021 8A83 MOV DPH,R2 0023 120000 R LCALL ?C0015 0026 8002 SJMP ?C0016 0028 ?C0015: 0028 E4 CLR A 0029 73 JMP @A+DPTR 002A ?C0016: ; SOURCE LINE # 14 0041 7E00 MOV R6,#00H 0043 900000 R MOV DPTR,#fptr 0046 E0 MOVX A,@DPTR 0047 FC MOV R4,A 0048 A3 INC DPTR 0049 E0 MOVX A,@DPTR 004A FD MOV R5,A 004B 8982 MOV DPL,R1 004D 8A83 MOV DPH,R2 004F 120000 R LCALL ?C0017 0052 8002 SJMP ?C0018 0054 ?C0017: 0054 E4 CLR A 0055 73 JMP @A+DPTR 0056 ?C0018:
Both are true (see K&R).
void f(void) { } int array[10]; void main(void) { void (*fptr)(void); int* iptr; fptr = &f; fptr = f; fptr(); (*fptr)(); iptr = &array; iptr = array; }
Both are correct. Also see:
http://www.mightywords.com/browse/details_bc05.jsp?sku=MWBCBZ&privateLabel=false
