anyone out there..pls help me out!.. im having problems writing a program using uVision2 for a 8052 developement kit. problem no.1: I have a Waveform of unknown freq from a swipe card which has TTL voltage of 0 and 5v. we need to design a program using C to count the time between the very 1st 2 high voltage (1st 2 high V) problem no.2: Next we hav to decode the waveform using a table. Basically its a Magnetic Swipecard we hav to decode, track 2 (eg 411557, 5bits per character) half the program has been written so far but we can;t seem to output it to the LCD display... HELP ME ANYONE PLEASE!!!... Desperate. ps: any qns, pls feel free to email me arelius@visto.com
You should make use of the features of the Timer 2. You can feed the T2 input (Port 1) with a clock signal of a certain frequency... (maybe 100kHz) and use the T2EX input for the signal to be meassured. A 0->1 transition of it will cause an interrupt and the counter content will be captured in a certain 16-bit register. This way, you can meassure the period of the signal with the accuracy of your 100kHz clock. The Timer 2 has to be configured in capture mode. The operation of it is described pretty well in the datasheet of your processor. Take care Sven
Sven, This is the first time, ever, I have heard of clocking a timer with an external frequency. Please clarify your reasons for nut running T2 as a timer and using EX0 or EX1 to stop it. I am very curious as to why. Erik
Hi Erik, well, just looked it up again... you can sure use the internal clock too. I just remembered an old application of mine, where I used a variable external clock to meassure the length of something moving through a light barrier. The external clock was relative to the speed of the movement. So I was not sure, if the c51 would be able to use the internal clock for the capture mode... just too long ago :)) Take care Sven
