Does anyone now if it's necessary to keep the EEE flag set to 1 of the EECON register (register to manage the internal EEPROM), when you launch the programming sequence on the EEPL bits ?
If you are using a recent version of the Keil PK51, you may also take a look to: Keil\C51\EXAMPLES\FarMemory\E2PROM on 80C51RD2. This is a C example that uses far memory to address E2PROM.
Could you give me a correct link on your web site. I can't find your files of the examples program...
That was not a link. It was the path to the example program when you have installed the software. Jon
Ooops! Thx
