Here is a solution looking for a problem. It is a faster alternative to the Keil _lrol_ function, on average it requires only 30% of the time taken by _lrol_. _lrol_ is quicker when shifting one or two bits, but this function is faster on average. It is on my Keil wish list that _lrol_ should produce in-line code (as promised in the manual) when perfoming a shift of exactly one (which is very common when implementing LFSRs etc.) and should call a faster function like this one when the shift is longer or unknown. fast_long_roll() takes more code space than _lrol_, but deals with shifts in both directions. Unlike _lrol_, it is not affected by rolls greater than 31.
/***************************************************************************** * * Fast Long Roll * * Trigger: Call by any process. * * Input: l - 32-bit word to be rolled. * n - number of bits to roll positive for left, * negative for right. * * Output: returns l * * Function: returns 32-bit word in rolled state. * *****************************************************************************/ long unsigned int fast_long_roll( long unsigned int l, signed char n ) small { ACC = n; #pragma ASM MOV R2,A ; ANL A,#07 ; ADD A,#2 ; MOVC A,@A+PC ; SJMP ?table_end DB 0,2,4,8,16,32,64,128 ?table_end: JZ ?roll_x_end ; ; MOV R1,A ; ; R4R5R6R7 ; A = nn l = ABCDEFGH XCH A,R7 ; A = GH l = ABCDEFnn MOV B,R1 ; A = GH l = ABCDEFnn MUL AB ; A = gh l = ABCDEFnn XCH A,R7 ; A = nn l = ABCDEFgh MOV R0,B ; XCH A,R6 ; A = EF l = ABCDnngh MOV B,R1 ; A = EF l = ABCDnngh MUL AB ; A = ef l = ABCDnngh ADD A,R0 ; A = ef l = ABCDnngh XCH A,R6 ; A = nn l = ABCDefgh MOV R0,B ; XCH A,R5 ; A = CD l = ABnnefgh MOV B,R1 ; A = CD l = ABnnefgh MUL AB ; A = cd l = ABnnefgh ADD A,R0 ; A = cd l = ABnnefgh XCH A,R5 ; A = nn l = ABcdefgh MOV R0,B ; XCH A,R4 ; A = AB l = nncdefgh MOV B,R1 ; A = AB l = nncdefgh MUL AB ; A = ab l = nncdefgh ADD A,R0 ; A = ab l = nncdefgh XCH A,R4 ; A = nn l = abcdefgh ; XCH A,R7 ; A = gh l = abcdefnn ADD A,B ; A = gh l = abcdefnn XCH A,R7 ; A = nn l = abcdefgh ; ?roll_x_end: ; MOV A,R2 ; ; JNB Acc.3,?roll_x8_end ;roll eight ; R4R5R6R7 ; A = nn l = ABCDEFGH XCH A,R7 ; A = GH l = ABCDEFnn XCH A,R6 ; A = EF l = ABCDGHnn XCH A,R5 ; A = CD l = ABEFGHnn XCH A,R4 ; A = AB l = CDEFGHnn XCH A,R7 ; A = nn l = CDEFGHAB ?roll_x8_end: ; ;roll sixteen JNB Acc.4,?roll_x16_end ; R4R5R6R7 ; l = ABCDEFGH XCH A,R4 ; A = AB l = nnCDEFGH XCH A,R6 ; A = EF l = nnCDABGH XCH A,R4 ; A = nn l = EFCDABGH XCH A,R5 ; A = CD l = EFnnABGH XCH A,R7 ; A = GH l = EFnnABCD XCH A,R5 ; A = nn 1 = EFGHABCD ; ?roll_x16_end: ; #pragma ENDASM return( l ); }
Slightly improved version:
/***************************************************************************** * * Fast Long Roll * * Trigger: Call by any process. * * Input: l - 32-bit word to be rolled. * n - number of bits to roll positive for left, * negative for right. * * Output: returns l * * Function: returns 32-bit word in rolled state. * *****************************************************************************/ #pragma ASM $REGUSE _fast_long_roll( A, B, R4, R5, R6, R7 ) #pragma ENDASM long unsigned int fast_long_roll( long unsigned int l, signed char n ) small { ACC = n; #pragma ASM ; JNB Acc.3,?roll_x8_end ;roll eight ; R4R5R6R7 ; A = nn l = ABCDEFGH XCH A,R7 ; A = GH l = ABCDEFnn XCH A,R6 ; A = EF l = ABCDGHnn XCH A,R5 ; A = CD l = ABEFGHnn XCH A,R4 ; A = AB l = CDEFGHnn XCH A,R7 ; A = nn l = CDEFGHAB ?roll_x8_end: ; ;roll sixteen JNB Acc.4,?roll_x16_end ; R4R5R6R7 ; l = ABCDEFGH XCH A,R4 ; A = AB l = nnCDEFGH XCH A,R6 ; A = EF l = nnCDABGH XCH A,R4 ; A = nn l = EFCDABGH XCH A,R5 ; A = CD l = EFnnABGH XCH A,R7 ; A = GH l = EFnnABCD XCH A,R5 ; A = nn 1 = EFGHABCD ; ?roll_x16_end: ; ANL A,#07 ; ADD A,#2 ; MOVC A,@A+PC ; SJMP ?table_end DB 0,2,4,8,16,32,64,128 ?table_end: JZ ?roll_x_end ; ; MOV R1,A ; ; R4R5R6R7 ; A = nn l = ABCDEFGH XCH A,R7 ; A = GH l = ABCDEFnn MOV B,R1 ; A = GH l = ABCDEFnn MUL AB ; A = gh l = ABCDEFnn XCH A,R7 ; A = nn l = ABCDEFgh MOV R0,B ; XCH A,R6 ; A = EF l = ABCDnngh MOV B,R1 ; A = EF l = ABCDnngh MUL AB ; A = ef l = ABCDnngh ADD A,R0 ; A = ef l = ABCDnngh XCH A,R6 ; A = nn l = ABCDefgh MOV R0,B ; XCH A,R5 ; A = CD l = ABnnefgh MOV B,R1 ; A = CD l = ABnnefgh MUL AB ; A = cd l = ABnnefgh ADD A,R0 ; A = cd l = ABnnefgh XCH A,R5 ; A = nn l = ABcdefgh MOV R0,B ; XCH A,R4 ; A = AB l = nncdefgh MOV B,R1 ; A = AB l = nncdefgh MUL AB ; A = ab l = nncdefgh ADD A,R0 ; A = ab l = nncdefgh XCH A,R4 ; A = nn l = abcdefgh ; XCH A,R7 ; A = gh l = abcdefnn ADD A,B ; A = gh l = abcdefnn XCH A,R7 ; A = nn l = abcdefgh ; ?roll_x_end: ; ; #pragma ENDASM return( l ); }
