I'm using the Cypress FX-2 board. They include a sample called bulkloop.c that allows you to loop data out to BULK IN EP's 2 & 4 and back via BULK OUT EP's 6 & 8. When i try this the Host Writes to EP's 2 & 4 go just fine but Host Reads from EP's 6 & 8 always send a NAK back to the host. The code for the FX-2 looks simple enough but I cant figure out why BULK IN EP's 6 & 8 always NAK. Is anyone else working with this board? I'd sure like to bounce information and ideas around. Also are there any other forums around for this, any other sample code available anywhere? I'm looking for resources. Source below: Thanks Eric
void TD_Poll(void) // Called repeatedly while the device is idle { WORD i; WORD count; // check EP2 EMPTY(busy) bit (bit0) in EP2468STAT (SFR), core set's this bit when FIFO is empty if(!(EP2468STAT & bmEP2EMPTY)) // if EP2 isnt empty { // check EP6 FULL(busy) bit in EP2468STAT (SFR), core set's this bit when FIFO is full if(!(EP2468STAT & bmEP6FULL)) // if EP6 isnt full { // setup AUTOPOINTER(s) in SFR space APTR1H = MSB( &EP2FIFOBUF ); APTR1L = LSB( &EP2FIFOBUF ); AUTOPTRH2 = MSB( &EP6FIFOBUF ); AUTOPTRL2 = LSB( &EP6FIFOBUF ); count = (EP2BCH << 8) + EP2BCL; // loop EP2OUT buffer data to EP6IN for( i = 0x0000; i < count; i++ ) { // setup to transfer EP2OUT buffer to EP6IN buffer using AUTOPOINTER(s) in SFR space AUTODAT2 = AUTODAT1; } EP6BCH = EP2BCH; // high speed usage EP6BCL = EP2BCL; // arm EP6IN EP2BCL = 0x80; // re(arm) EP2OUT } } // check EP4 EMPTY(busy) bit in EP2468STAT (SFR), core set's this bit when FIFO is empty if(!(EP2468STAT & bmEP4EMPTY)) { // check EP8 FULL(busy) bit in EP2468STAT (SFR), core set's this bit when FIFO is full if(!(EP2468STAT & bmEP8FULL)) { // setup AUTOPOINTER(s) in SFR space APTR1H = MSB( &EP4FIFOBUF ); APTR1L = LSB( &EP4FIFOBUF ); AUTOPTRH2 = MSB( &EP8FIFOBUF ); AUTOPTRL2 = LSB( &EP8FIFOBUF ); count = (EP4BCH << 8) + EP4BCL; // loop EP4OUT buffer data to EP8IN for( i = 0x0000; i < count; i++ ) { // setup to transfer EP4OUT buffer to EP8IN buffer using AUTOPOINTER(s) in SFR space AUTODAT2 = AUTODAT1; } EP8BCH = EP4BCH; // high speed usage EP8BCL = EP4BCL; // arm EP8IN EP4BCL = 0x80; // re(arm) EP4OUT } } }
