Hello ! I want to save a constant factor in the code area on a spezific adress. How can I do that ?? I used these commands but I got a warning (Warning L15: CODE SPACE MEMORY OVERLAP FROM 0000H TO 0000H)... header file: extern unsigned char code code_uc_c; source file: unsigned char code code_uc_c _at_ 0x0028 = 0x23; if I use it without = 0x23 it works.. thank you for your help, florian.
Go back and read the section in the manual about _at_ - particularly the restrictions on its use! Then do a search, as this has been discussed many times before!
