Hello, I'm using C51 v 5.10 BL51 v 3.52 uVision v 1.24 1.) When I link object files in the following order, the startup code is not run. Inspection of the .hex file shows that there is no jump to the startup code. The line to invoke the linker by uVision is: C:\C51\BIN\BL51.EXE C:\SIEMENS\INIT.OBJ, C:\SIEMENS\STARTUP.OBJ, C:\SIEMENS\myCode.OBJ TO C:\SIEMENS\myCode RS (256) But if I invoke like: C:\C51\BIN\BL51.EXE C:\SIEMENS\STARTUP.OBJ, C:\SIEMENS\INIT.OBJ, C:\SIEMENS\myCode .OBJ TO C:\SIEMENS\myCode RS (256) The startup code runs fine and the jump to it can be easily seen in the first line of the hex file. Can anyone help me? Thanks, Bob
testing - ignore
Thanks Jon, The myFile.obj is object from myFile.c Basically the issue is if I list INIT.obj before STARTUP.obj in the linker list, the startup code does not get jumped to. If STARTUP.obj is linked before INIT.obj, everything runs fine.
Is it possible that all your files are from assembly sources (or C translated to assembly sources)? In which case just add a dummy C file to your project.
