Hello, I'm new to the 8051 and I am hoping someone has had to solve a similar problem to this before, although this is not an 8051 specific problem. Can someone give me assistance on how to convert a 12-digit binary coded decimal value to hexadecimal on the 8051? The BCD value is packed into 6 consecutive bytes. Any help would be appreciated. Regards, Stephen McSpadden.
The following code will convert the array of BCD digits in variable bcd to a 32-bit binary value in hex. Of course, a 32-bit binary cannot hold the full range of values that you can get from 12 decimal digits. This code just indicates how to go about the conversion.
main( void ) { data unsigned char bcd[6] = { 0x00, 0x00, 0x12, 0x34, 0x56, 0x78 }; data unsigned char loop; data unsigned char data *p; data unsigned long hex; hex = 0; loop = sizeof( bcd ); p = &bcd[0]; do { hex = hex * 10; hex = hex + ( *p >> 4 ); hex = hex * 10; hex = hex + ( *p & 0x0F ); p++; }while( --loop != 0 ); }
Graham has presented such a nice, elegant algorithm for converting BCD to binary. Should we have a competition to see who can write the smallest version measured using the compiler listing file? Jon
I don't think you want to be issuing a challenge like that to Graham! ;-) Are you excluding solutions using #pragma ASM... ?
