Hi, I get a curious result when compiling such a following code :
typedef union { unsigned char cCtrlFullByte; struct { unsigned char bEnable : 1; unsigned char cUnused : 7; } cCtrlStruct; } CtrlUnion; void main (void) { unsigned char dummy = 0x55; CtrlUnion xdata bitUnion; bitUnion.cCtrlStruct.bEnable = dummy & 0x40; return; }
MOV A,#0x55 ANL A,#0x00 MOV R7,A MOV DPTR, #0x0000 MOVX A,@DPTR ANL A,#0xFE ORL A,R7 MOVX @DPTR, A
In the standard it is stated that a bit-field is interpreted as a signed or unsigned integer type consisting of the specified number of bits. In your case it's unsigned integer 1 bit wide. Conversion rules for unsigned integers imply that the compiler should take the LSB, which it did. Regards, Mike
Why not, but how do you explain a different casting rule when the destination is a "real bit"
void main (void) { unsigned char dummy = 0x55; bit bitValue; bitValue = dummy & 0x40; return; }
MOV A,#0x55 MOV C, 0xE0.6 MOV 0x20.0, C
MOV A,#0x55 ANL A,#0x44 ADD A,#0xFF MOV 0x20.0, C
The bit type is a specific Keil extension, so they can implement it in the most efficient, target-specific way they can think of - without having to worry about any other ANSI constraints; Bitfields, on the other hand, are standard ANSI - so Keil may well be constrained in their implementation (and implementations of bitfields are notorious for being inefficient!) BTW: Have you disabled the defualt ANSI Integer Promotions?
> The bit type is a specific Keil extension, > so they can implement it in the most efficient, > target-specific way they can think of - without > having to worry about any other ANSI constraints; Why not, but it is not a reason to have opposite result when using a bit type or a bit in bit-field type !!! > Bitfields, on the other hand, are standard ANSI > - so Keil may well be constrained in their > implementation (and implementations of bitfields > are notorious for being inefficient!) My problem is not efficiency but COHERENCY of the compiled code ! If I used a bit-field type stored in BDATA, or a byte with sbit declarations, the result will be different !!! So, if you write your code using Keil bit type, the result will be good, whereas using bit-field type (for portability), the result will be false !!! Not really coherent ! ;-( Is that a compiler bug or a normal issue ? > BTW: Have you disabled the defualt ANSI Integer Promotions? Obviously Yes, but no change. Arnaud DELEULE
