I am trying to generate an interrupt when a byte is received via the serial port of an Atmel AT89C51. I am not having much luck. Here is my code:
#include <reg51.h> #include <CTYPE.H> #include <STDIO.H> #include <INTRINS.H> int big_d, count, dogg, i, j; void rcv (void) interrupt 4 { big_d = _getkey(); count++; dogg = 1; RI = 0; } void main(void) { SCON = 0x50; /* SCON: mode 1, 8-bit UART, enable rcvr */ TMOD |= 0x20; /* TMOD: timer 1, mode 2, 8-bit reload */ TH1 = 253; /* TH1: reload value for 9600 baud @ 11.0592MHz */ TR1 = 1; /* TR1: timer 1 run */ TI = 1; /* TI: set TI to send first char of UART */ ES = 1; /* enable serial interrupts */ dogg = 0; count = 0x30; do{ putchar(count); for(j=0; j<255; j++) { for(i=0; i<255; i++) { _nop_(); _nop_(); _nop_(); _nop_(); } } if(dogg == 1) { putchar(count); printf("\n"); putchar(big_d); printf("\n\n\n"); dogg = 0; } }while(1); }
