I am trying to generate an interrupt when a byte is received via the serial port of an Atmel AT89C51. I am not having much luck. Here is my code:
#include <reg51.h> #include <CTYPE.H> #include <STDIO.H> #include <INTRINS.H> int big_d, count, dogg, i, j; void rcv (void) interrupt 4 { big_d = _getkey(); count++; dogg = 1; RI = 0; } void main(void) { SCON = 0x50; /* SCON: mode 1, 8-bit UART, enable rcvr */ TMOD |= 0x20; /* TMOD: timer 1, mode 2, 8-bit reload */ TH1 = 253; /* TH1: reload value for 9600 baud @ 11.0592MHz */ TR1 = 1; /* TR1: timer 1 run */ TI = 1; /* TI: set TI to send first char of UART */ ES = 1; /* enable serial interrupts */ dogg = 0; count = 0x30; do{ putchar(count); for(j=0; j<255; j++) { for(i=0; i<255; i++) { _nop_(); _nop_(); _nop_(); _nop_(); } } if(dogg == 1) { putchar(count); printf("\n"); putchar(big_d); printf("\n\n\n"); dogg = 0; } }while(1); }
There are several problems with this program. 1. Global interrupts are not enabled. You must set the EA bit to enable them. 2. You set the TI bit initially to allow transmission of characters, however, this triggers an interrupt. Your interrupt routine does not handle sending characters. 3. You interrupt calls _getkey to retrieve the character from the SBUF. The problem with this is that _getkey clears the TI bit. Your interrupt ALSO clears the TI bit. So, if a serial character is receive between these times, it will be lost. 4. I can only assume that this program is designed to receive serial characters in the interrupt and to transmit serial characters in a polled fashion. This is BAD. A serial I/O example program already exists for the 8051. Take a look at http://www.keil.com/download/docs/intsio.zip.asp for a working example. Jon
Thanks for the info. Do I need to send my characters in my interrupt subroutine as well? I would like to just use the interrupt to receive characters so I can increment a counter everytime I receive a byte. Jake
Do I need to send my characters in my interrupt subroutine as well? Well, technically speaking, no, you don't need to send characters from the interrupt. However, if you enable the serial interrupt, you will receive an interrupt when TI is set or when RI is set. And, you will have to do a lot of work to get around this. The example link that I provided already handles serial transmit and receive in the interrupt, so you don't have to write anything. Jon
"The example link that I provided already handles serial transmit and receive in the interrupt, so you don't have to write anything." Yes, I have used the example code that Jon cited and can confirm that it really does work - just like it says on the tin!
"I would like to just use the interrupt to receive characters so I can increment a counter everytime I receive a byte." Increment the counter only if (RI) Erik
