Can I get some info on how to initialise the Code memory and data memory 1)Unsigned char xdata temp _at_ 0x8000; 2)unsigned char code temp1_at_0x8000; In the cases mentioned above , how do i initialise 20 bytes of data conitiugously
You might want to look at; http://www.keil.com/forum/msgpage.asp?MsgID=4481
This is a very frequent topic - just scroll back through the list, or use the 'Search' Any particular reason why you need to initialise specific locations?
Thanks for the reply Well I do not have specific reason , to initialise xdata to specfic memory location. This is for exploring different possibilitis to initialize data , a lookup table for example I have one question below What are the options to be set in the KEIL to generate the Hex code from 0000 location Thanks Regards SHASHI B R
"This is for exploring different possibilitis to initialize data" If you're programming in 'C', just leave it to the compiler! "I have one question below" Sounds like a new question - so best to start a new thread with it.
If you really want to hack an initialisation to a fixed memory location, you could compile a file which might say:
#pragma SRC unsigned int xdata variable = 0x1234;
EXTRN XDATA variable
EXTRN XDATA(variable)
