Question 1: I am needing to perform I2C or SPI communication among 8031s, but I cant use open-collector pins or serial pins. I have 03 free pins on port 1. Is it possible without additional hardware ? Question 2: I am neending to connect a 80C31 to GPS antenna that uses 9600,8,odd,1 standard. So I am needing to program the microcontroller on mode 3 how showed bellow void serial_config(void) { ES = OFF; // Disable Serial Interrupt TR1 = OFF; // Turn OFF the timer 1 TMOD = (TMOD & 0x20) | 0x20; // Timer 1 - Mode 2 - Automatic TL1 = 0xFA; // 9600 bps TH1 = 0xFA; // TR1 = ON; // Turn ON the Timer 1 PCON = 0x80; // SMOD = 1 --> double the rate SCON = 0xD0; // SM0 = 1 SM1 = 1 --> mode 3 of communication // REN = 1 --> Enable Reception RI = OFF; // Enable RI ES = ON; // Enable Serial Interrupt } void int_serial(void) interrupt 4 { if (TI) { RS_tx_int = ON; // free to new transmition TI = OFF; // Reset the Flag } if (RI) { // If exists data on reception put_data_rx_buffer(SBUF); // read the data and put it on reception buffer RI = OFF; // Enable reception to new data } } void serial_out(byte aux) { while (RS_tx_int == OFF); // wait to transmit the data TB8 = calculate_parity(aux, ODD_PARITY); // calculates the odd parity based on "Aux" SBUF = aux; // transmit next data RS_tx_int = OFF; } So, on mode 3, when I connect the MCU on PC runs ok but when I connect on GPS antenna do not run. Are there other configuration to do on setup of serial communication ? (like priority IP register ?) Please let me see if my code is correct. Best Regards
