memory class definitions.
Hi
i'm having a program for ST10 which has lots of variables defined. It works fine when I run it using MOnitor program i.e. through an external RAM. But when i change the settings to run it from flash, it is giving a warning after linking as follows:
"L5: section located outside class area."
I have changed my memory model to the largest option available, but stil the same problem.
Pls help
Regards
Sonali
