Hi I am trying to use the automatic address recognition on the Philips 87LPC764. I am having trouble using the serial window in the debugger to transmit 11 bit data so that the simulated 87LPC764 can receive the data byte plus the additional 9th bit used in the automatic address recognition. Has anyone got any suggestions on how to 'transmit' a byte from the serial window with a 9th bit set? Thanks, Nick Daniel
Have you tried it via the 'Peripherals' menu?
In the command window, just type
SIN = value
Thanks Jon, that command does what I need. Cheers, Nick
