I have installed C51 V6.14 on Windows Me. When I try to compile any program I get an error message related with C51.dll. The same software version instaled on Windows 95 works fine. Can anybody help me? Thanks.
No, C51, BL51 and A51 don't work running them from the command-line. I get the same error message.
Do the separate tools work if you run them individually from the command-line?
The error message I get is: C51 caused an error in C51.DLL C51 will be closed I've the same problem with BL51 and A51. The operating system version is: Windows Me 4.90.3000
Precisely what error message do you get?
