Will the eval version simulate the Compare Capture Unit, the five ports, timer 0, 1, 2 for the Infineon C508? In a previous message it says that PK51 will definitely simulate all the on-chip peripherals.
The following peripherals are simulated for the C508 (even in the evaluation version): http://www.keil.com/DD/nDetails.asp?O=SM&DID=3107&VN=Infineon+C508 Jon
