I've noticed that the following definitions generate different data results. Perhaps, I'm overlooking something. #define TEMP (*(unsigned char xdata *) 0x10F0)) unsigned char xdata sutton2, *sutton; unsigned char xdata * xdata sutton3; sutton = &TEMP; sutton3 = &TEMP; sutton2 = TEMP; If XDATA location 0x10F0 has 0x35, then the following compilation occurs: 'sutton' has the value X:10F0, which is correct. 'sutton2' has the value 0x35, which is correct. 'sutton3' has the value D:10F0, which is not correct. To complicate things, if I swap the 'sutton2' and 'sutton' declarations to: unsigned char xdata *sutton, sutton2; then 'sutton' has the value D:10F0, which is not correct. There is no DATA location 10F0, therefore garbage is the result. The source code generated for *sutton being first in the declaration list is a 2 byte XDATA pointer, which points to the DATA area. If *sutton is not the first declaration in the list, it is a 3 byte pointer (which works correctly) that points to XDATA. Anyone know what the problem is and why the sutton3 declaration listed above does not force the compiler to generate a pointer that points to XDATA? Thanks Sutton Mehaffey Lookout Portable Security sutton@lookoutportablesecurity.com
The following code works great for me.: C Compiler: C51.exe V6.20c
#include <intrins.h> #define TEMP (*(unsigned char xdata *) 0x10F0) void main ( void ) { unsigned char xdata *sutton, sutton2, xdata *sutton3; sutton = &TEMP; sutton3 = &TEMP; sutton2 = TEMP; _nop_(); }
I ran the exact same code and sutton and sutton3 contain D:10F0 and sutton2 is correct and holds the value from X:10F0. So, I don't know the problem. Maybe an emulator problem, which is what I am using to view results.
What version of the compiler are you using? Maybe there is a difference in mine. I'm using 6.01.
What exactly are you trying to achieve? Have you carefully considered: 1. the distinction between "Generic" and "memory-specific" pointers; 2. the Keil syntax for specifying both the location of a pointer, and the memory space which it addresses; 3. the fact that XDATA memory-specific pointers are 2 bytes, while idata, data, bdata, & pdata memory-specific pointers are one byte; 4. Generic pointers are always 3 bytes. I'm afraid I don't have time to wade through all your layers of multiple indirection, but I suspect that your problem lies in one (or more?) of the above.
Yup! I'm running the lastest version. C Compiler: C51.exe V6.20c
Maybe an emulator problem, which is what I am using to view results. Which emulator are you using? Have you contacted the emulator vendor to see if they have updated software? Jon
I tried the following:
unsigned char xdata TEMP _at_ 0x10f0; unsigned char xdata sutton2, *sutton; unsigned char xdata * xdata sutton3; void main (void) { sutton = &TEMP; sutton3 = &TEMP; sutton2 = TEMP; }
