LCD Interface
I am trying to interface an LCD with the C167 microcontroller. I went thru
the application note 161 where it explains
how to interface the 8051 micocontroller with the ST7066 LCD. I will not be using the ST7066 LCD with the C167 but I wanted to moreless use the 8051 template. Or is this code just for simulation purposes? Well I tried to modify the code but unfortunately it did not work. I think I am missing a library or need to modify the code some more.
Can anyone help me? Is there another library I should use besides reg167, stdio and intrins. and if not what could be the problem?
Thanks a bunch,
LILY
  • I am using a serial display 4x20c from Matrix Orbital.
    I have also being working with the DAVE CD. It creates the skeleton for you C-program but I have been having problems with it because I am not sure on the project settings. Have you ever worked with DAVE?
    I do have the Keil CD but I can't seem to find the "Final work on 8051". Can you be more specific on where this info. could be?
    Thanks,
    LILY
    Thanks,
    LILY
