I am new to the RS232 and Hyperterminal. I am using a Philips 89C664 and I want to know how to print characters onto the Hyperterminal. I am testing this by using the HELLO.c file given with the software...
/*------------------------------------------------------------------------------ HELLO.C Copyright 1995-1999 Keil Software, Inc. ------------------------------------------------------------------------------*/ #include <reg66x.h> /* special function register declarations */ /* for the intended 8051 derivative */ #include <stdio.h> /* prototype declarations for I/O functions */ //#ifdef MONITOR51 /* Debugging with Monitor-51 needs */ //char code reserve [3] _at_ 0x23; /* space for serial interrupt if */ //#endif /* Stop Exection with Serial Intr. */ /* is enabled */ /*------------------------------------------------ The main C function. Program execution starts here after stack initialization. ------------------------------------------------*/ void main (void) { /*------------------------------------------------ Setup the serial port for 1200 baud at 16MHz. ------------------------------------------------*/ #ifndef MONITOR51 SCON = 0x50; /* SCON: mode 1, 8-bit UART, enable rcvr */ TMOD |= 0x20; /* TMOD: timer 1, mode 2, 8-bit reload */ TH1 = 221; /* TH1: reload value for 1200 baud @ 16MHz */ TR1 = 1; /* TR1: timer 1 run */ TI = 1; /* TI: set TI to send first char of UART */ #endif /*------------------------------------------------ Note that an embedded program never exits (because there is no operating system to return to). It must loop and execute forever. ------------------------------------------------*/ while (1) { P1 ^= 0x01; /* Toggle P1.0 each time we print */ printf ("Hello World\n"); /* Print "Hello World" */ } }
It works with the uVision2 Serial #1 window. So why bother with Hyperterminal? But if you must use it, make sure that you have correctly configured the port in Hyperterminal; ie, * COM port number; * Baud Rate; * Parity; * Stop bits; * Flow control.
I gotta to work...thanks a lot....
