RS232 with Hyperterminal
I am new to the RS232 and Hyperterminal. I am using a Philips 89C664 and I want to know how to print characters onto the Hyperterminal. I am testing this by using the HELLO.c file given with the software...
HELLO.C
Copyright 1995-1999 Keil Software, Inc.
#include <reg66x.h>                /* special function register declarations   */
                                  /* for the intended 8051 derivative         */
#include <stdio.h>                /* prototype declarations for I/O functions */
//#ifdef MONITOR51                         /* Debugging with Monitor-51 needs   */
//char code reserve [3] _at_ 0x23;         /* space for serial interrupt if     */
//#endif                                   /* Stop Exection with Serial Intr.   */
                                         /* is enabled                        */
The main C function.  Program execution starts
here after stack initialization.
void main (void) {
Setup the serial port for 1200 baud at 16MHz.
#ifndef MONITOR51
    SCON  = 0x50;		        /* SCON: mode 1, 8-bit UART, enable rcvr      */
    TMOD |= 0x20;               /* TMOD: timer 1, mode 2, 8-bit reload        */
    TH1   = 221;                /* TH1:  reload value for 1200 baud @ 16MHz   */
    TR1   = 1;                  /* TR1:  timer 1 run                          */
    TI    = 1;                  /* TI:   set TI to send first char of UART    */
#endif
Note that an embedded program never exits (because
there is no operating system to return to).  It
must loop and execute forever.
  while (1) {
    P1 ^= 0x01;     		    /* Toggle P1.0 each time we print */
    printf ("Hello World\n");   /* Print "Hello World" */
It works with the uVision2 Serial #1 window.
thanks
Tommy
