What does the following mean? #pragma src #prgma OT (8) Thanks
#pragma src The compiler will generate a source file (.src extension), rather than an object file. The SRC file must then be assembled using the assembler to produce an object module. #pragma OT(8) The compiler will run with optimization set to level 8.
They mean, "it's time to read the manual!" ;-)
sorry Mr. Neil ...the user manual is too boring for the beginners! Thanks
But you need read manual for more things ...
I said it was necessary; I didn't say it was exciting! ;-)
