Between the Summary and Message boxes on the "Post A Message" page add something like the following: Please using the
and
Let me try that again. Between the Summary and Message boxes on the "Post A Message" page add something like the following: Please using the <pre> and </pre> tags surrounding any code posted. It would save Andrew a lot of postings.
So it would! I would suggest that it should also have links to the Knowledge Base search, Forum search, and FAQs, and say "search these resources before posting" It should also explain how to access the PDF manuals via the 'Books' tab in the uVision Project window. Might cut down a bit on the number of times the same old questions get repeated? ;-) BTW: are <pre> and </pre> case-sensitive? Let's just try it:
lowercase
If you tell them about the non standard pre & /pre tags they will use them. Sorry to say, your other excellent suggestions will be ignored.
Check out the side-bar, guys. :-) Jon
OK - It's there. Jon
Are and case-sensitive? This is now fixed:
This is < pre > text.
This is < PRE > text.
