I have a program compiled to target a DS87C520. The source is A51 assembly and C code mix. The compiled output is in Intel Hex file format. The Keil Simulator executes the program just fine. We also have an ICE that runs the program. However, when I burn the hex record into the actual micro, I get nothing. Any ideas? I can email source, hex file, etc if anyone wants to take a look. Thanks, Chris Beattie
Are you using on-chip XDATA? If yes, did you enable it in the startup code? Jon
Jon, I finally got the Keil Hello example working. I had to reorder the Intel Hex file so that the records were sorted in increasing order of addresses. Apparently our programmer is a POS. Is there any way to make uVision2 spit out ordered Intel Hex files? Thanks, Chris Beattie
