Compiler name mangling
Having wondered why the linker couldn't locate a code segment which I'd specified as part of the BL51 command line, I took a look at listing file to discover that the compiler had (somewhat arbitrarily) appended an underscore to some of the function names, hence the link error. Is there a means of inhibiting (or predicting)this annoying compiler characteristic?
Thanks!
  • Well, the first port of call for all such questions is always the Compiler manual! ;-)
    You didn't say which toolset - I assume we're talking C51?
    When you say "append" I assume you mean "prefix?"
    The compiler adds various prefixes depending on whether & how parameters are passed.
    See the "Segment Naming Conventions" section in the manual
    The error probably means that you've mismatched your function prototypes & definitions.
    What exactly is the error you get?
    What does it tell you if you look up the error in the help?
