Can't compile...
I written this code and it compiles just fine. However, when I tried to include <stdio.h> library to use with my hyperterminal, it says that it compiled, but can not link. Here is the message that it gave me...
ERROR L107: ADDRESS SPACE OVERFLOW
SPACE: DATA
SEGMENT: _DATA_GROUP_
LENGTH: 0070H
My memory model is "Small: variables in DATA". When I changed it to compact or large, my program will compile and link, but it behaves differently when I put program it to the Philips 89C664..
thanks
Tommy
  • I written this code and it compiles just fine.
    So why is your title "Can't Compile?!" ;-)
    See the recent Thread, Differences between compiler versions
    When you include the extra functions, they require some space for parameters & their own internal variables as well as just code space - which is why you got the DATA space overflow in Small model.
    When you switch to COmpact or Large, your code starts using "External" [1] memory, MOVX instructions, and the DPTR.
    There could be a hardware fault with your XRAM, or a timing difference which causes your code to fail, something might be corrupting your DPTR(s), your Startup code might not be properly initialising your XRAM & revealing flaws like uninitialised variables in your code, you may have mis-used memory-specific pointers, etc, etc
    [1] "External" here means "outside the CPU core" - although it may be packaged within the IC, it is still outside the core & has to be addessed with MOVX.
  • The REAL problem here is that in SMALL memory model, you are limited to a total of 128 bytes of variable space, period.
    In large model, you are limited to 64K bytes of variables space.
    So, the following program:
    unsigned char array [121];
    void main (void)
    will compile and link just fine in LARGE model but not in SMALL model (the register bank of R0-R7 takes up the first 8 bytes of memory).
    You should probably take a look at a databook to get a better understanding of the architecture of the 8051.
    Jon
