I'm using the uVision2 8051 eval version trying to see if it's worth leaving my normal asm enviroment. Natualy I have some asm functions that I would like to take with me, but I need to figure out how to call my asm functions. I have three different senearios that are quiet common among my routines, and I'm looking for help to integrate the two worlds of programming. This is how I would like the C code to look: unsigned char portbit unsigned char databyte unsigned char stream[8] bit Reset(portbit) byte DataIO(portbit,databyte) void DataOut(portbit,databyte) The asm works like this: Reset returns true or false in carry, and accesses a certan output bit. DataIO both sends and returns data in the accumulator. It, too acesses a port bit. DataOut is basically the same as the above, but it returns nothing. It will however change the contens in the stream. In other words... How do I make sure that the C routines communicates using the accumulator and carry. I'm looking forward to hear what to do. Regards, Flemming Steffensen
Well the first thing to do is, of course, read the manuals! I think the section Interfacing C Programs to Assembler might be appropriate? ;-) Note that all the manuals are on the CD, and accessible via the 'Books' tab in the uVision Project window. Also try a search of this forum, and the Support Knowledgebase
Hi Andrew, I've not recieved any manuals with the eval release of uVisuion2 I have. Where are they available? I allready tried a search in this forum, but apparently "C", "asm", "assembler" and "function" are stripped from any search string, making it a hard to search for item. But thanks for your input anyway. Regards.
As I said before, Note that all the manuals are on the CD, and accessible via the 'Books' tab in the uVision Project window. https://www.keil.com/demo/cdrom.asp If you downloaded your demo, I think there's an option to download with or without manuals.
