Syntax error using uvision2
I have just started using your uvision2. I received your tool when I bought the phillips development system.
Here's my problem:
I am targeting a philips 764 controller, this is a 8051 compatible,
all code was written in assembly language.
When I go to build an existing file which used the 'b' register I get the following error
error A48: DATA-ADDRESS EXPECTED
the line of the code it is issuing this error for is below
clr b
Thanks,
John
  • Hi,<br>
    <br>
    <br>
    I have just started using your uvision2. I received your tool when I bought the phillips development system.<br>
    <br>
    Here's my problem:<br>
    <br>
    I am targeting a philips 764 controller, this is a 8051 compatible,<br>
    all code was written in assembly language.<br>
    <br>
    When I go to build an existing file which used the 'b' register I get the following error<br>
    <br>
    error A48: DATA-ADDRESS EXPECTED<br>
    <br>
    the line of the code it is issuing this error for is below<br>
    <br>
    clr b<br>
    <br>
    Thanks,<br>
    <br>
    John
  • Hi,<br>
    <br>
    <br>
    <br>
    <br>
    <br>
    <br>
    <br>
    <br>
    clr b<br>
    <br>
    Thanks,<br>
    <br>
    John
