Error 231 with compiler version 6.14
I get the error 231 ("redefinition" of mib_type ) with the compiler version 6.14 when I'try to compile the flollowing code:
---Header File--------
#define u unsigned
typedef struct mib_data_st
u char x;
u char y
}mib_data_st;
extern code char **mib_type[8];
extern code mib_data_st mib_data[8];
---End of Header File---
---C-File---
code char *mib_type0="\x1""* 0 Hz *";
code char *mib_type1="\x1""* 1 Hz *";
code char *mib_type2="\x1""* 2 Hz *";
code char *mib_type3="\x1""* 3 Hz *";
code char *mib_type4="\x1""* 4 Hz *";
code char *mib_type5="\x1""* 5 Hz *";
code char *mib_type6="\x1""* 6 Hz *";
code char *mib_type7="\x1""* 7 Hz *";
code char *mib_type8="\x1""* 8 Hz *";
code char **mib_type[8+1]={
&mib_type0,
&mib_type1,
&mib_type2,
&mib_type3,
&mib_type4,
&mib_type5,
&mib_type6,
&mib_type7,
&mib_type8
---End of C-File---
This problem did not occur with the Version 6.10.
Has everyone any idea??
  • I'm surprised that v6.10 let you get away with it:
    ---C-File---
    In the header file, you have said "mib_type is an array of eight pointers to pointers to chars;"
    In the 'C' file, you have said "mib_type is an array of nine pointers to pointers to chars;"
    The Compiler is right to complain - you need to make up your mind what size you want the array to be! ;-)
    Note that it's not a bad idea to include your extern declarations in the same file as the actual definitions - it allows the compiler to catch errors like this!
    ---C-File---
