Is this a bug?
Hi, all
I found there is likely a bug in keil c51's compiler(V6.02, Optimization Level = 8)
When compile and link the following program lines:
#include <absacc.h>
#include <reg52.h>
#define ADDR201 XBYTE[0x8000]
bdata unsigned char D201;
sbit green = D201^2;
void main(void)
  while(1)
    green = 1;
    ADDR201 = D201;
    green = 0;
    green = 1;
    ADDR201 = D201;
the result was:
RSEG ?PR?main?TMAIN
main:
; SOURCE LINE # 8
; SOURCE LINE # 9
?C0001:
; while(1)
; SOURCE LINE # 10
; SOURCE LINE # 11
; green = 1;
; SOURCE LINE # 12
SETB green
; ADDR201 = D201;
; SOURCE LINE # 13
MOV DPTR,#08000H
MOV A,D201
MOVX @DPTR,A
; green = 0;
; SOURCE LINE # 14
CLR green
; green = 1;
; SOURCE LINE # 15
SETB green
; ADDR201 = D201;
; SOURCE LINE # 16
MOVX @DPTR,A
; SOURCE LINE # 17
SJMP ?C0001
; END OF main
END
there was an obvious error in the assembly code for source line # 16 !
there should be another line:
MOV A,D201
before the line:
MOVX @DPTR,A
Is it a bug?
