When I use the new update C51 compiler C51 v620c to translate the following file with SRC directive, the result seems not correct,would keil surport please check it.
#pragma SRC unsigned int ui_MixedParms(unsigned char ucA,bit btCheck, unsigned int uiB){ if (btCheck) return(ucA + uiB); return(uiB - ucA); }
; TST_C_Func2.SRC generated from: TST_C_Func2.c NAME TST_C_FUNC2 ?PR?_ui_MixedParms?TST_C_FUNC2 SEGMENT CODE ?DT?_ui_MixedParms?TST_C_FUNC2 SEGMENT DATA OVERLAYABLE ?BI?_ui_MixedParms?TST_C_FUNC2 SEGMENT BIT OVERLAYABLE PUBLIC ?_ui_MixedParms?BIT PUBLIC ?_ui_MixedParms?BYTE PUBLIC _ui_MixedParms RSEG ?DT?_ui_MixedParms?TST_C_FUNC2 ?_ui_MixedParms?BYTE: uiB?042: DS 2 RSEG ?BI?_ui_MixedParms?TST_C_FUNC2 ?_ui_MixedParms?BIT: btCheck?041: DBIT 1 ; ; unsigned int ui_MixedParms(unsigned char ucA,bit btCheck, unsigned int uiB){ RSEG ?PR?_ui_MixedParms?TST_C_FUNC2 _ui_MixedParms: USING 0 ; SOURCE LINE # 2 ;---- Variable 'ucA?040' assigned to Register 'R5' ---- MOV R5,AR7 ; if (btCheck) ; SOURCE LINE # 4 JNB btCheck?041,?C0001 ; return(ucA + uiB); ; SOURCE LINE # 5 MOV A,R5 MOV R6,#00H ADD A,uiB?042+01H MOV R7,A MOV A,R6 ADDC A,uiB?042 MOV R6,A RET ?C0001: ; return(uiB - ucA); ; SOURCE LINE # 6 CLR C MOV A,uiB?042+01H SUBB A,R5 MOV R7,A MOV A,uiB?042 SUBB A,#00H MOV R6,A ; } ; SOURCE LINE # 7 ?C0002: RET ; END OF _ui_MixedParms END
?_ui_MixedParms?BYTE: ucA?040: DS 1 uiB?042: DS 2
