Hello, I'd like to ask a little bit help. I downloaded the mcb517_i2c aplication note. I try to read the LM75 tempereture sensor with the bit_bang i2c routines. The problem is... There is a 16 bit temperature register and I can read only the high byte . I use the following program . . unsigned char data_in; i2c_start(); i2c_write(0x91); data_in=i2c_read(); i2c_stop(); I try to use the unsigned int instead unsigned char and modified the i2c_read routin to read 16 bit but no succes. Any advice? Cheer George
Hi George! My LM75 library code looks like this:
#include "i2c.h" #define uchar unsigned char #define LM75_SLA 0x49 #define LM75_TEMPADR 0x00 #define LM75_CONFADR 0x01 #define LM75_THYSTADR 0x02 #define LM75_TOSADR 0x03 uchar get_temp( int *halfdegree ) { uchar sendbyte; uchar rbuf[2]; sendbyte = LM75_TEMPADR; if (i2c_xceive( LM75_SLA, &sendbyte, 1, rbuf, 2 )){ *halfdegree = -1; return -1; } else { *halfdegree = ((((int)rbuf[0]) << 8) + rbuf[1]) / 128; return 0; } }
/*------------------------------------------------------------------------- Transmit data then receive data on I2C-Bus: sla : Slave Adress xbuf : data buffer (transmit ) xmit_count: Number of bytes. Has to be <= 16!!! rbuf : data buffer ( receive ) recv_count: Number of bytes. Has to be <= 16!!! returns -1 if error -------------------------------------------------------------------------*/ extern int i2c_xceive( uchar sla, uchar xbuf[], uchar xmit_count, uchar rbuf[], uchar recv_count );
Thanks for eweryone's help. As some people point me the problem is the ack and the're right. Thanks again George
You can also test the LM75 with my I2C-Simulation DLL. You'll find it in http://www.c51.de part µVision2 DLLs
