µVision 2 V6.10 Can´t modify bytes in memory window
I'm using µVision2 V6.10 in Eval-Mode. My problem is that i cannot modify
bytes in the memory window. The procedure i'm using is the following:
-entering memory adress
-right mouse-click on byte to modify
-entering modifyte byte in pop-up window
But with this procedure no bytes change their value !???
(When the assembler-programm change some bytes the changes are shown in the
memory window!!)
