I have a problem with accessing integer pointers and integer variables.the compiler places first the msb and then the lsb. example :memory location is 0xc000,i place an integer var ,it is placed as follows msb at 0xc000 and lsb at 0xc001. but what if i want to do the reverse . if i access the variable and display it using pointer or macro xword ,it displays the reverse binary pattern. Help please.
