Have the following problem: I need to create a library with many functions. Some functions will be used by some projects and others by other projects. The important is to have only one library version to manage. Big problem: I am getting Warning 16: uncalled segment... for the functions not being called! And I think that XDATA is being taken? CODE I think is not being taken by the unused functions? Does anyone knows a way to avoid this?
Put one function per C file and rebuild the library. If you have a C file with lots of functions, the obj file will include ALL of these functions. If you link with this library but you don't call all of the functions in a module (obj file) you will receive the error you mention. Jon
