putchar works but printf does not ... my putchar is used by printf so the problem must be in my code somewhere?? I started deleting sections of code until my printf started to work ... then I narrowed it down to a single statement ... statement in - it worked, statement out - printf didn't work ... the statement was in a routine that did not get executed .. deleting other statements made printf work ... the program was only 5161 bytes when I reached to go/no go condition Have you ever heard of anything like this??? Any ideas on how to find out what is going on??
Data Overlaying?
this works:
s[0] = 'A'; s[1] = 'B'; s[2] = 0; printf ( s );
printf ( "AB" );
I assume you are using Keil's printf in the library. We (I) would probably need to see your putchar to see how it is written. Does your putchar follow the ansi standard for its arguments? In your example though with printing the variable vs. printing a constant, I think one would be in data space somewhere (xdata or idata), while the constant string 'AB' would be stored in code space... purhaps this is the problem? I do agree we the other response of overlays being an issue. Such a powerful feature can also create endless headaches.
How would the string constant being stored in code space be a problem? The printf routine gets passed the starting address of the string and something that tells it the address is code space. Nothing should be able to overlay the code space. I have narrowed the problem down to the starting address of the string pool. If the start address is 1FFE printf works. If the starting address is 2001 printf does not work. Not working means that printf acts like it is printing nulls. The putchar routine is exactly like the sample given for interrupt driven serial i/o. I am stumped. I guess my next move is to start trying to trace through the printf function.
How would the string constant being stored in code space be a problem? The printf routine gets passed the starting address of the string and something that tells it the address is code space. In theory this is true, but from experience I've seen incorrectly written/compiled code that will try to use a MOVX to fetch from code space... what you get is obviously garbage. It was just a shot in the dark
