Hi all, I'm using RTX51-TINY in my application. I included rtx51tny.h in the files, and tried to link them with BL51 as follows: bl51 module1.obj, module2.obj, module3.obj rtx51tiny However, the linker complains about the rtx51.lib file: MS-DOS BL51 BANKED LINKER/LOCATER V2.01 COPYRIGHT KEIL ELEKTRONIK GmbH 1987 - 1991 *** FATAL ERROR 210: I/O ERROR ON INPUT FILE: EXCEPTION 0021H: PATH OR FILE NOT FOUND FILE: C:\C51PROGR\LIB\RTX51.LIB Can anyone tell me what I'm missing? thanks for reading...
Shouldn't that be:
bl51 module1.obj, module2.obj, module3.obj, rtx51tiny.lib
Dear Neil, Thanks for the reply, but the documentation gaved me that syntax. It says: ******************************* Generation Example: C51 BEISPIEL.c BL51 BEISPIEL.OBJ RTX51TINY ******************************* I had too many modules to link and was doing the compile+link process in a batch file. I think that BL51 parameter line was too long to evaluate. The problem disappered when I used the linker as follows (where FILELIST.L51 is a text file containing the parameters): BL51 @FILELIST.L51
What directory did you install the Keil tools into? According to the error message, your installation directory for the C51 compiler is: C:\C51PROGR\ This doesn't look right to me. It should probably be something like C:\KEIL\C51. Jon
