Hi all, I'm using RTX51-TINY in my application. I included rtx51tny.h in the files, and tried to link them with BL51 as follows: bl51 module1.obj, module2.obj, module3.obj rtx51tiny However, the linker complains about the rtx51.lib file: MS-DOS BL51 BANKED LINKER/LOCATER V2.01 COPYRIGHT KEIL ELEKTRONIK GmbH 1987 - 1991 *** FATAL ERROR 210: I/O ERROR ON INPUT FILE: EXCEPTION 0021H: PATH OR FILE NOT FOUND FILE: C:\C51PROGR\LIB\RTX51.LIB Can anyone tell me what I'm missing? thanks for reading...
What directory did you install the Keil tools into? According to the error message, your installation directory for the C51 compiler is: C:\C51PROGR\ This doesn't look right to me. It should probably be something like C:\KEIL\C51. Jon
