According to K&R: x *= y + 1 is equivalent to: x = x * ( y + 1 ) And other assignment operators including modulo should be handled similarly. However, the following function does not work as I expected.
void test() small { unsigned char x,y; x = 7; y = 7; x++; x %= 256; y = ( y + 1 ) % 256; }
; FUNCTION test (BEGIN) ; SOURCE LINE # 1002 ; SOURCE LINE # 1006 ;---- Variable 'x' assigned to Register 'R7' ---- 0000 7F07 MOV R7,#07H ; SOURCE LINE # 1007 ;---- Variable 'y' assigned to Register 'R6' ---- 0002 7E07 MOV R6,#07H ; SOURCE LINE # 1009 0004 0F INC R7 ; SOURCE LINE # 1010 0005 EF MOV A,R7 0006 75F000 MOV B,#00H 0009 84 DIV AB 000A AFF0 MOV R7,B ; SOURCE LINE # 1012 000C EE MOV A,R6 000D 04 INC A 000E FD MOV R5,A 000F 0E INC R6 ; SOURCE LINE # 1014 0010 22 RET ; FUNCTION test (END)
In your program...
x %= 256;
Thanks for the reply. I came across the problem in a buffer handling function where I was incrementing read/write pointers that index a circular buffer. In the original application, the modulo values were #define'd as the length of the buffer array - rather than being written as literal. I only hit a problem when I increased the buffer length to the maximum value of 256. I can understand where the division by zero comes from, on reflection, it may be a side effect from suppressing interger promotion. However, it does not seem right - especially as the calculation for 'y' comes out as I would expect. I cannot see any reason why 'x' and 'y' should not be equal at the end of test(); I am still baffled by the assembly language emitted by the compiler - although the compiler generally seems very good it does sometimes seem to loose the plot. The compiler emitted four assembly language instructions for source line 1012 where only one was really necessary.
