Problem with "TO" command in linker command file
I have quite a lengthy (but otherwise functional) linker command file I use to position all my segments to my liking.
What I want to do, however, is force the output name of the ABS and the HEX file.
The Utilities book shows the "TO Sample.ABS" as a way to do this, but I cannot find a place to put such a line in the linker command file where it doesn't cause a linker error.
Example of my .lin file (clipped)
CODE (2000H, seg1( 100h), seg2) &&
STACK( ?Stack ( 0B0H ) ) &&
RAMSIZE(256) &&
NOOVERLAY NOLINES PAGELENGTH(10000)
Where in this file can I place the "TO" directive where it won't hatch the command line?
